Hello everyone,
I'm trying to reinstall the spring for the seat lap bar. I had to take out the seat bar switch to test it, and at the time it seemed I had to remove the spring, as well (though I'm not sure if there was a way around that).
Anyway, it seems like it should be simple enough to do, but I cannot quite figure out how to recompress the spring or install it back together, and I feel as if I'm missing some trick or I'm doing something out of order.
I have a little homemade spring compressor, but it doesn't fit into the area. I also tried using the spring retaining bolt and tightening it and holding it compressed with zip ties, but they seem to loosen up.
I've been trying to install it with the seat bar switch and seat bar bolt connected first, as the seat bar arm needs to have the bushing installed first, etc.
Or should the spring go on first and then attach the yoke with the pin and retaining clip? Then deal with the seat bar bushing/switch? Are you able to pivot the arm out to install the bushing and switch, if the spring is attached first? Or is it under too much tension then?
I must be doing something wrong, so if someone could please let me know what the right way of doing this is, I'd appreciate it.
Thanks.
Joe
Thanks.
Joe
