Hello everyone, thanks for suggestions on other past topics/
I've picked up a late 90's Bobcat 863F and pretty much fixed up everything except it's overheating. I'm new to this particular engine, but a pretty reasonable amateur mechanic. Some details:
- Deutz 1011F
- Runs okay at low throttle, but temp slowly keeps building under heavier operation to temperature red-line. There is an engine temp overheating light that also turns on.
- It's got about 3300 hrs, runs strong, plenty of power, etc.
- I've pressure washed it extensively, including the drive belts/pulleys/etc, which were all pretty caked
- Oil level reads normal.
- The cooling fan is working, blows strong.
- The radiators look clean, but I'm going to pull the engine oil cooler out entirely to check its backside
- *** When it gets hot, a LOT of oil is weeping out of the fuel injector area at the top of the engine, which is baffling to me.
- I have not been able to check the oil pressure yet, but that's next too.
It would appear that there is a clog somewhere. I think I'm going to drain the oil and see what else I can find. I read somewhere there are three different thermostats that can get clogged. Can anyone chime in on that? The Deutz manual isn't very revealing.
Thanks in advance!
- Deutz 1011F
Thanks in advance!
