Hello all,
I acquired this machine a few month back and have more or less fixed a variety of issues, including overheating and fuel/oil leaks.
Today I bolted the muffler back on top of the engine, and after some manual fuel pumping and jump starting, got her running again. She'd been sitting probably 2 months. I was surprised the fuel had drained out of the system, but she didn't fire at least until I pumped and bled a bit.
So I ran the machine pretty hard for a while, 10-15 minutes say, and then shut her down. When I started it again, it ran for maybe a minute and then completely started coughing and running really rough, plumes of intermittent white and gray exhaust, no power, just BAD. Eventually quit. Oh oh. I fired it up again, which it did okay, but the symptoms persisted. Except there would be intermittent moments where it seemed to run okay for a few seconds. I did this probably 20-30 times to limp back to my repair area in the intervals when it ran a little smoother. Strangely enough, it sort of helped a little to have a load on the engine.
So what could be wrong here? I will say that there was a definite ticking before, which I can't identify necessarily as having been a valve.
I also don't understand how the fuel metering and injection quite works in the Deutz. It has this "distributed" injector pump at each cylinder, and I don't know off hand how the fuel metering or governing works. Hence why I'm asking here.
Possible problems:
1) Easy answer: lots of water in the fuel? I'll do some draining. Fingers crossed it's that simple...
2) Something wrong with the injector pump system? Why would it be intermittent?
3) Valve issue?
4) Blown head gasket? But again, why intermittent performance? The machine also isn't overheating, runs around 215-235 depending on the load, which seems to be right for this Deutz.
Any suggestions appreciated.
Possible problems:
3) Valve issue?
