WHAT I'VE DONE: My Bobcat 863 (year = 2000 with about 2300 hours) quit running with ¾ tank of fuel. I replaced the fuel filter and the fuel riser pump. I couldn't get the hand-squeeze bulb (also replaced) to pull fuel up into the fuel pump and filter. I filled the tank with the bulb removed until fuel spilled out the open fuel line. I reconnected the bulb, pumped it, bled the injector lines, and she started right up.
WHAT I SUSPECT HAPPENED: If the fuel line that goes down into the top of the tank were to have broken off, then when the fuel level got to ¾ of a tank, I assume that the Deutz engine's fuel riser pump would then start sucking fuel tank "air" and the engine would quit. Also the hand-squeeze bulb would probably not pump anything but air. Filling the tank would get the level up above the broken internal fuel tank line.
HERE'S MY QUESTION(s): Does this sound reasonable as a source of my engine failure? Is there a way to test this short of pulling out the fuel line to check it visually? As the fuel is sucked down during use, where does the fuel tank get its replacement air so that it does not pull a vacuum? Is there a one-way valve on any air intake line to the tank?
(this is my first post, so I'm anxious to see what kind of response I get here -- thanks in advance)
