Bobcat 773 with Kubota v2203 engine .... Installing a block heater....
apehf
Sherbrooke
Sheperd
Howdy!! I am planning on installing a block heater on my 773 and would like some assistance/coaching as to how to proceed. I have a Philiiips &Temco 3100025 block heater. So where do I install it on the block? Thank you in advance for your help!!!
I woke up in a cold sweat because I forgot to tell you: point the element a little to the right of straight up, so the metal doesn't touch metal. And hurry, it looks like you're five minutes too late already!:D
DIYDAVE
MD
Sometimes the location can be a bear, to get the old FP out, specially if there is a firewall, in the way... I remember on one, I drilled a hole, to get the bar of a slide hammer in, then used a drill, to drill a small hole, in the FP, and put the screw, of the dent puller in the hole, screwed it in, and yanked the FP out, with the dent puller/slide hammer... ;)
