Terryz
I have a Bobcat 773 G, ser # 519013216. machine was in the shop for a traction lock problem; fixed traction lock problem, after sitting for 2 weeks waiting for parts started machine up to remove safety bar to leave shop have no lift or tilt function. turn key on, ach lite comes on; lift and tilt light on left panel gives initial flash; when running after pushing operate pad lite is off. checking codes it shows a 32-34 code which is tilt actuator not in neutral. The shop manual doesn't what the the codes represent or how to fix the problem. As part of fixing the traction lock we found corroded fuses in fuse panel which we corrected if that has any bearing on the problem. Does anyone have any ideas about this? Thanks, Terry
