Bobcatdaddy
Got a 01 763G 2200 hrs I bought couple weeks ago I've ran it probably 9hrs started and shut it off a dozen or more times since I've got it. Went to get the machine from a little job I was doing the other day, turned the key over to start and nothing instrument panel wouldn't light up no beep nothing it was like it didn't have a battery on it. So I get out look at battery cable connections try again still nothing. After that i tried a new battery I had just to be certain it wasn't the battery, still no luck. So I get my test light and multimeter start checking fuses and stuff. Big fuse above battery is good, fuses in fuse block were good with test light, switched relays to check them still no luck. Not 100% sure on what wires to check on ignition panel, I borrow a friends ignition panel off another bobcat and mine still won't do anything. Not sure what wires do what so not sure exactly which ones to trace, I do know I've got 12volts on a red/white wire at ignition panel but doesn't seem like it's sending 12 volts out to light up instrument cluster, power to fuel shut off solenoid or anything else. I can hit the light button and it turns on and hour meter lights up but when I hold to get codes it doesn't do anything. Almost like computer is not talking to something but I'm not sure how all that works. I looked grounds over and all look good with the eye. Not sure if it's any correlation but after running the machine for first hour or 2 at random seat bar light would go off along with traction, lift tilt and then come back on and be fine for 5 or 10 min. So I checked a few things out after that and seen + battery cable was loose so I tightened and didn't have that problem again worked awesome rest of the time I used it. Got done turned it off and 2 or 3 days later when I went to get it I have the problem I have now. I know there's several guys on here with a wealth of knowledge on these machines and I'm just looking for other things to check. All input is appreciated. I'll list below what I've checked because I'm sure after this long post be hard to remember what I've even typed.
Problem-763G bobcat nothing happens when key is turned, like it doesn't even have a battery on it. When light button is pushed lights come on and hour meter lights up with hours displayed. Will not retrieve codes or say none when light button is held.
Things checked and tried
1.battery
2.put a good key switch panel in it (key style with warning lights above key)
3.big fuse above battery have 12v on both sides of fuse
4.fuses and relays in fuse box. Checked fuses with test light and switched relays with good one
5.inspected harness plug below cab that feeds cab for rubbed wires
6.checked in behind left right and center panel for rubbed wires
7.tried extra left hand panel had
8.have 12v on red/white wire going into key switch panel
9.visually looked at all grounds
10.cleaned battery post and and terminals on battery cables at battery side
11. I zip tided fuel shut off solenoid and crossed starter and it fired right up but still no power to instrument cluster or traction lock solenoid or hydraulic lock.
Looking for any advice on what to try, sorry for long post. Thanks in advance
1.battery
