Bobcat 753 won’t tilt
Austin9159
Georgia
Bought this machine from a guy who said it sat for a few years and now doesn’t work right. Lift arms will go up but not come down, tilt does work. Tore the valve body down and replaced o rings and cleaned it, reinstalled then the issue was backwards, would go down but not up. Pulled the hydraulic solenoid, cleaned and tested then reinstalled. Now I’m back to only the arms going up. The weird part is I crank it, push the operator button and for about 2 secs the tilt works and the lift works correctly, then it stops and goes back to only lift. Where should I start looking? This machine doesn’t have a boss option and the bics lights are solid on all but the seat(flashes constant) and traction lock(flashes 5 times)
crewchief888
NWI
sounds like one of the auxiliary stems is stuck.
try this
start it up, hit the PTO button
turn on the aux, HOLD the paddle switch on the RH handle one way or the other and see if your hyds start working normally
Austin9159
Georgia
Okay I’ll try that, I hit the switch yesterday and could hear the system deadhead but didn’t try it while using the foot controls.
Austin9159
Georgia
Okay that worked! Started machine, hit the trac lock button and only had lift. Hit the aux unlock button and move the switch on the drive handle to the far right and all functions start working. Move the switch to the middle or left and you hear the engine is under a slight load and bucket functions don’t work again. So now what do I need to replace?
Austin9159
Georgia
Unplugged both both aux solenoids and it works fine. Plug one in, works fine, plug the other in and it stall. Put the wires on opposite solenoids and the probablem follows the wires. Does this mean my hand controls are to blame?
crewchief888
NWI
id guess that your trigger on the RH handle is stuck. most likely due to a broken spring in the handle assy.
might play around with the trigger and see if you can get it to shut off
Austin9159
Georgia
Mhmm okay, I’ll check that. I did notice when I pulled the trigger it didn’t seem to move. Please explain to me what the trigger does vs the flipper switch and the aux switch
willie59
Knoxville TN
Service Manager
Thumb switch is for two way proportional control of aux function, the finger trigger locks the aux on so you don't have to hold the thumb switch all the way when using something like a brush cutter that remains running instead of intermittent use like a grapple.
