tylercooney
I think I ran the Bobcat out of diesel, but I'm not convinced since the tank still said 1/4 tank. Anyway, I filled the tank back up, unscrewed the fuel/water separator and filled it with diesel and re-attached it. Pumped the manual pump primer a couple hundred times, started it, pumped some more, restarted, pumped some more, restarted and it finally ran on its own without pumping...for about 3-4 minutes. I drove it those 3-4 minutes did some dirt moving and then stopped to answer my phone, but left it running, in about 30 seconds of stopping it sputtered and died again. I've tried using the same procedure mentioned above to get it to start again but it's not working. I took the hose off the intake side of the bulb and held my finger there to make sure there was suction and there was suction at the bulb and it stayed compressed when I squeezed it. I reattached that hose and detached the other side to see if it would squirt any fuel when squeezed and it did not. Someone mentioned to me that the hose may be disconnected at the tank, does this sound feasible? If so, how do I check? Just yank on it? and of so it is disconnected, how do I get to the tank to reattach?
Thanks for your help,
Tyler
Tyler
