We have a 2008 Bobcat 331 G AACS11188 since it was new, cab machine with 1400 hrs, it's been mostly trouble free. The other week I started the machine and I walked away from it for 10 mins or so. When I got back to it I heard a noise and realized the starter was still running. Looked inside and the code showing is 22-02. By the time I turned it off the starter was really hot and trashed. I replaced the starter assy and now when I start the machine the starter stays engaged and I get code 22-02.
If I remove the starter solenoid wire after starting the bobcat the starter disengages and we can operate normally other than the 22-02 code.
I've replaced the starter relay, checked the continuity of the starter signal wire and the computer J plug, correct battery voltage and clean battery connections. I looked over the wiring harness for rubbed areas but I don't see anything odd.
Has anybody had this type of issue before? Any ideas what else I can check or is this a problem inside the computer?
Thanks,
Jeff
Thanks,
Jeff
