Bob35
Bob35
Ireland
540 170 JCB year 2011.steering module replaced back Axel sensor replaced and still not selecting steering modes.front Axel sensor OK.can ya bypass it for four wheel steer or has anyone got a solution.
jcb jeff
United Kingdom
Are the switches adjusted correctly which means when washer passes the blue switch the led will light up on these the front switch locks out the back and vise versa .check wiring on the plugs at the switch connectors at the chassis plug for the harness.Check fuses is the mode switch on dash working correctly .You can flash a spanner across the switches on the blue part and it should change modes .Make sure the blue plastic bits on switches is not damaged
Can you get front and rear wheels straight if not it wont lock out .
jcb jeff
United Kingdom
Might need to re phaze steering but i guess the rear switch not aligning so wont change modes also check wiring on solenoids for steer mode at base of cab front right
Bob35
Ireland
The wheels are straight on the back.only front ones turning.mode light flashing up code 13 on the dash.
