Does anyone know if the Bevel Gear Housing is plat steel, cast steel, or Cast Iron? I have noticed some hairline cracks near bolt holes on the transmission side of the casing and curios if it's something that can be welded.
Now that you mention loose bolt, One crack is spanning from one bolt that doesn't protrude through the housing as the others do. But, I did have hairline cracks on the top housing cover also like the machine had been in some major jolt. However, I did grove, and grind those cracks with success using fluxcore wire. The reason for fluxcore, was simply because strength wasn't my concern as much as sealing the housing up.You can do a spark test and cast steel will cut with a cutting torch too. For welding I think you'd want to preheat a couple hundred deg's. before welding and use 7018. Grind a little past the cracks to make sure they don't go further than first thought. You could drill holes at the ends of the cracks but if everything is ground out and fully welded should be good. Peening the welds is also a good idea. Check for loose bolts or something that may have contributed to the cracks. Cast steel doesn't normally crack but on a dozer anything is possible.
Yes sir, it was self shielded, but every single crack seemed to only be running across a bolt hole. I know I will end up having to re-tap the threads, but so far no cracks have developed in the new welds. I also didn't have any cracking and popping after the welds were completed like I had before on a exhaust manifold years ago. Also I think I forgot to mention. This entire case/housing is constructed by welding the internal components, and walls together rather than a one cast construction. based on my observations, center punch test, and grinding grooves on the hairline cracks on the top plate, I feel it is 1/2-3/4 inch plate steel. But I still want to be certain before I go any further with the weld process.What type of flux-core and did you preheat? A flux-core wire could be similar to 7018 but if it was just a general purpose self-shielded flux-core the repair may not last long. It would be like putting a Band-Aid on when you needed stitches. Keep a close eye on it.
I apologize, I forgot to mention, I did not preheat, it tends to stay rather warm in Alabama most of the year, with rare cold winters reaching 10-19 degrees. On average 30-48 degrees in winter.What type of flux-core and did you preheat? A flux-core wire could be similar to 7018 but if it was just a general purpose self-shielded flux-core the repair may not last long. It would be like putting a Band-Aid on when you needed stitches. Keep a close eye on it.
