I've bought a used 1990 580K, but apparently the previous owners determined that instruments were simply not needed. Nothing works. I haven't started the process of back tracing the wiring from the instruments to the source yet. Next step. But I did remove the cluster box and start testing it. I replaced the fogged gauge cover by cutting out the fogged area with a Dremel and gluing a piece of clear lucite from Home Depot on the top. Simple and inexpensive. I've tested the continuity of the circuit board in back and confirmed that there's no breaks in the copper strips. Now I'd like to bench test each of the gauges so I know at least that they should work. Volt meter is easy - just test on a car battery. But not sure of the others. Suggestions for testing Tach, hours meter, water temp, oil temp and fuel level? With things available in the above average house garage? I'm remote from the hoe so can't test with it. I can supply power to the gauges from a car batt, but not sure about what the sending units provide to the gauges.
Based on the service manual wiring diagram it appears that the hours meter's simply attached to the key switch, leading me to believe that a continuous 12v supply would run the meter. ?
I'll worry about the warning lights later as well. That would be more a wiring problem anyway.
Thanks for advice.
Thanks for advice.
