Bell30e recalibration of bin tip sensor
nielv
South Africa
Managing Director & Diesel Mechanic
Hi Cue.
What is the serial number of the machine?
I have manuals regarding the machine, But I need to know what PIN model the machine is. Can share them with you.
nielv
South Africa
Extraction form the manual:
1. Make sure that there is enough room above the
bin to be able to lift it fully. Look for any hazards
like power lines or overhead obstructions.
2. Make sure there is no one directly behind the
truck as the bin may hit them as it is lifted. If
possible, cordon off this area to make sure no
one enters it while you are calibrating the
sensor.
3. Make sure that the bin is empty to prevent tipping
a load/water/heavy objects in an undesirable
place.
4. Start the engine.
5. Go to Menu> Machine Config> Bin.
6. Ensure that the bin is completely on the
chassis.
7. Select "Zero Position" and then press and hold
the middle SDC button to accept the bin zero
calibration.
8. Once the value has been accepted, raise the
bin fully. The bin will go all the way to the mechanical
end stops when the Bin Calibration
menu is selected.
9. Scroll to "Fully Lifted" and then press and hold
the middle SDC button to accept the bin fully
lifted calibration.
