Answer these for me since I just found this thread
1. How does the engine run? Is it smooth through the rpm range, unloaded and loaded?
The engine does run smooth while the truck is both loaded and unloaded.
2. Is there excessive black smoke out the exhaust when under a heavy load?
No, no excessive smoking
3. What is the hottest temp you have seen with the ir gun at the thermostat housing versus what the gauge is showing at the same time?
While shooting the hot side of the radiator we read 190F. This was at idle after coming back from power breaking the truck and the temp had already came back down. The gauge vs the IR gun were reading the same. We also replaced both the gauge and sending unit to try and rule out a faulty temp sending unit and gauge. Looking at the gauge in the cab however the temp will run up past 215-220F.
4. Is the temp sender near the exhaust and is the exhaust leak free?
We have looked for exhaust leaks and found none. We thought that this too could be an issue but so far have found nothing.
The thermostat is a water flow and temp regulator. Its job is to keep the engine at a specific temp range and adjusts the water flow accordingly. The coolant in your system absorbs heat......the airflow through your radiator cools the coolant.
Being that from what I have read so far.....it sounds like the timing may be a bit off under the engine load and creating excessive heat.
I will call and check with the engine rebuilder I used and ask them about this. Wouldn't an out of time engine run poorly given this is a diesel engine?
JMHO of course
