mutti_wilson
I've got a new to me BD2G DD dozer that is acting up. When I pull back on the steering levers, the clutches work properly. I can stop the machine by pulling both of them and they work smooth. The problem I'm having is the brakes work very sporadically. Sometimes they lock up great and sometimes I just track straight. I pulled the pedal brake mechanism and lubed it since they were basically frozen up. I can hit the brake while pulling on the lever and that will normally turn the machine. In the right brake cavity there is some fluid in the bottom. Not sure where it's from. Is just an adjustment needed?
