earthscratcher
where do you guys, that do in house battery cable stuff buy your supplies, crimpers,wire, clamps ?
Their shipping is crazy expensive.Dell City (www.delcity.net)
That maybe due to you location but to me in pa I think it was 15 bucks the last time I ordered from themTheir shipping is crazy expensive.
It's often more than the product when I've checked. Wasn't much better when I lived in IdahoThat maybe due to you location but to me in pa I think it was 15 bucks the last time I ordered from them
I'll have to pay more attention next time im shopping there maybe it slipped under my noseIt's often more than the product when I've checked. Wasn't much better when I lived in Idaho
I always preferred welding cable, more flexible and if my high school science classes were right the finer strands actually are able to carry more amps for the same cross section.welding wire is ok for battery cables?
Polar Wire Products is always the correct answer. https://polarwire.com/
Looks like it.Always correct for Alaska or good for the lower 48 also?
Problem I've seen with welding cable is when corrosion gets started, it flies through like fire through dry grass.I always preferred welding cable, more flexible and if my high school science classes were right the finer strands actually are able to carry more amps for the same cross section.
Of course, but the indent type still works fine. Just need to do it all proper and heat shrink to prevent corrosion. What style cable ends are you looking at? Actual crimped terminal cable ends or crimped lugs to marine terminals?has far has crimpers is the try- form better then the indent type?
They are in the lesser 48 tooAlways correct for Alaska or good for the lower 48 also?
