Backing up with a single axle jeep
mazadi88
Texas
Hey fellas, had a quick question about backing up a 4 axle lowboy with a single axle jeep. My question is, is there a secret to it or is it one of those things you just have to figure out or try to avoid if possible? Thanks in advanced fellas.
Shimmy1
North Dakota
Just do it. Same as backing a gravity box, an anhydrous tank, or a dolly-type pup behind a tandem. Just have to be patient and not oversteer.
redneckracin
Western PA
Civil Engineer
A jeep backups up like any other trailer. :D Sorry just poking fun. If you never backed up a hay wagon or a gravity wagon, you are in for a treat. Lots of practice is all I can offer on this one. I have been playing with tongue wagons for years and I get a little better at it every year, but I don't do it for a living either!
old-iron-habit
Moose Lake, MN
A two hundred inch wheel base on the tractor is not your friend either. The shorter the tractor the easier it is, but still dang diffucult if you need to back very far. Practice, practice, practice and look ahead to avoid as many of them situations as you can. My closest neighbor transfers truck from CA to MN for an outfit. When pulling three with the fronts riding on the one ahead he looks for his prking spots and motels carefully. Not fun at all when you can't pull out forward.
RZucker
Wherever I end up
Mechanic/welder
More than once I've cross chained the rear of a jeep to the deck of the main to get out of a tight spot... EMPTY only.
