Backhoe
Bhunter@
Tn
I have an M59 Kubota Backhoe and it"s smoking blue smoke and has no power when i push to go forward or backwards
NH575E
North, FL
Retired Machinist
Sounds like the engine is wore out. You need to start with a compression and leak down test.
Willie B
Mount Tabor VT
Electrician
I don't know the engine, I don't know if it has them. GM had engines in the 1990s had "umbrella seals" on the valve stems would crack & smoke like that.
KSSS
Idaho
excavation
I don't know anything about that machine, but if it has a turbo, I would check that, that is what it sounds like.
Welcome to the Forums Bh!
Like other have said start with the basics - air filter, turbo, ect.
