Thumb
Hi, I really like the thumb you designed, I just bought a JD 310sg extend and would like to make one for it.
Could you please send me the plans, rick2386@gmail.com
I really appreciated it.
I've been lusting for a backhoe thumb for years and finally decided to build one. I drew the plan up in autocad using a compilation of designs from different thumbs I've seen. When I get time I'm working on converting the 3D image to working and dimensioned drawings if anyone would like to build one similar to this one. I used heavy wall seamless tubing for the bushings and 2" CRS for the pins. Since I don't have a line bore and this is a budget project, I turned the pins for a .015 clearance. All the tines and support structure is 1/2" plate. I tacked it together with a MIG welder and welded the assembly with 5/32 7018. Photos show construction up to mounting on the dipperstick, I got busy and just had time to sandblast and need to paint it.
My .pdf 3D drawing file was over 100kb. If anyone would like a copy I can email it to them.
