This is a good indication of how patient I am (read:too many projects, not enough time).
I bought a trailer yesterday. I went with a 30ft tandem dual. Tandem dual because I don't like the scrubbing of the tridems, how they switch pivot tires etc. I really wanted oil bath axles because I'm sick of the mini crap bearings on my 10,000 lb GVWR wannabe 'equipment trailer' which is really just a car hauler.
Anyway the trailer came with the slip tank, pump, chains, boomers, ratchet straps, was 5-10 years newer and still cheaper than anything else I had seen within 400 miles, so I had to snap it up. It is a 30ft (deck + beaver tail) Gatormade. Has the torque tube, fairly low profile.
Pictured is my 98 3/4 ton with a semi-float 14 bolt and a 5.3, 4l80e in it. My big block truck with the 14b ff and my friends 7.3 dually will be the main tow rigs used with the trailer. Also.. I think the slip tank is empty (or mostly empty) and the helper bags are showing 40 lbs..
I'm not sure what the unloaded weight on it is.
