north1
First time purchase of a loader backhoe, specifically a case 590 sm series 2. Have used viscosity oil-case ih 251h ep nlgi no.2 lithium soap extreme pressure grease in all my agricultural equipment in the past. This was due to my father and his reluctance on having multiple grease guns with different types of grease. I have put my foot down and want to at least have another type of grease for pins and bushings. My problem is I have several pieces of equipment I have already used this grease in and don't want to run into compatibility issues.
So I will keep using the viscosity oil grease for roller/Timken bearings, and a 5% moly based grease for heavily loaded pins and bushings. Question is what will be compatible in the equipment I have already used the lithium grease in? Also, what brand of grease would be high quality but readily available. I use some Mobil oil products so have a good relationship with the Mobil rep, but wanted to get an unbiased opinion here.
