Backhoe gear oil mess
Discussion in 'Lubrication' started by bkj110, Apr 21, 2021.
  1. bkj110
    bkj110 Member
    Jun 25, 2019
    6
    Pittsburgh, PA
    E58FE6E6-09AC-4B54-8E24-830ED7D2A5B8.jpeg 7F58C1C2-8DAB-4BD6-AF86-086F9750997D.jpeg A0C1BF2B-DEA9-4907-9CAF-DD056CDC01F7.jpeg Case 580B I use at home, so minimal use & lots of sitting in Pennsylvania. Oil was drained/replaced spring last year, nothing terrible then, just old and some moisture. Standard issue 80/90 gear oil. I’m in process of splitting and found this mess, seems to have separated & the yellow dropped out/jellied. I’m thinking the pinion seal is letting shuttle oil in? I’ve been wrenching for almost 30 years and have never seen this, but this thing’s older than me
  2. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    2,441
    Equipment Mechanic/Technician
    Pennsylvania
    Welcome to HEF bk;)!
    Yuk!:(
    bkj110 and Vetech63 like this.
  3. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    3,230
    Oklahoma
    Kinda looks like my wife's banana pudding.
  4. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    6,182
    On A Riverbank in IL. USA
    Is the rubber boot on the gear shift missing ?
  5. Coaldust
    Coaldust Senior Member
    May 10, 2011
    958
    Cargo Tanks
    Wasilla and parts unknown
    Hello new guy!
    Vetech63 nailed this diagnosis. You gots the banana pudding.
  6. bkj110
    bkj110 Member
    Jun 25, 2019
    6
    Pittsburgh, PA
    It's not missing but more than likely not water tight, if new ones exist, I'll replace it. I split the tractor (needs a shuttle rebuild), the manual shows a double seal arrangement on the transmission input shaft but there's only one in place. It seems pretty old/stiff, no obvious problems though. The rest of the cover gaskets all looked good.
    When I drained the shuttle oil out to troubleshoot the very soft reverse, it was full of water too (front shuttle cover had no gasket or RTV).
    Thankfully enough this machine won't be sitting in the rain in a few months.
  7. Tinkerer
    May 21, 2009
    6,182
    Gona build a shed for it ?
    That boot should (hopefully) be available from CNH.
    I had a crappy one once and I was amazed how much water had gotten in the transmission.
  8. petepilot
    petepilot Senior Member
    Jul 7, 2018
    1,684
    central shenandoah valley va,
    we have a 460 Ih tractor factory fork lift. gears are whining in it` a check of the oil shows it to be full but i suspect it has water to` has sat outside for the past 7-8 yrs
  9. bkj110
    bkj110 Member
    Jun 25, 2019
    6
    Pittsburgh, PA
    Yeah, putting a lean-to addition onto the side of the shop so it'll at least be out of the rain. If lumber doesn't come down in price, I may just build the frame out of steel, it'll probably be cheaper :mad:
    Spud_Monkey and Tinkerer like this.
