View attachment 201708 While the more input, the better, before chasing the travel issues, let's start with something more simple.
No hydraulic function works correctly, so, as mentioned above, the pilot pressure is suspect.
And, without sufficient pilot pressure, nothing works right.
I'm saying stay away from the travel issues because even the loader arms respond poorly, which points to, if the pilot pressure is good, a problem with the gear pump.
There are 4 pumps...front to back, pilot, loader, travel 1 & travel 2.
The front 2 are gear pumps and, if you dont have gauges to test them, they can be easily dissected and inspected. Myself, I'd find gauges first.
And, all four pumps need sufficient oil supply.
The loader hydraulics are filtered with a horizontal filter under the passenger side of the cab. That cartridge has been known to suck shut on my 3 TL150 machines.
I believe a 1-1/16 or 1-1/8 wrench fits the hex at the rear. It won't affect travel, but it sure will affect loader operation.
Regardless, it absolutely should be changed, and the old one inspected.
