ASV RC85 Issues
5.9Jon
MB Canada
I know this is slightly off topic but in regards to joystick. Is it possible to change or source the buttons for the joystick? have 2 on mine that don't work and looking to change microswitches as opposed to whole handle.
5.9Jon
MB Canada
Thanks, I looked at that previously in this thread. While it has information regarding joystick assy. It does not show handle D&A. Or whether switches are replaceable or not. Is it safe to assume that the whole handle needs to be changed then?
Amadeus3
Maine
Bringing this back from the dead so hopefully it helps someone else. I fixed my issue. Turns out the pressure relief button on the top of the quick disconnect manifold block was stuck in the down position. I had to unscrew it and tap the bottom of it against the machine to get the plunger to retract. Took me a couple tries because it didn’t seat all the way the first time. I’m surprised how much the grapple will move with such a small gap in the valve.
I added a photo of the relief. It’s the little button thing on the very top of the block with the hex nut under it.
Anyway, thank you everyone for your help!
Tones
Ubique
Another thing to keep an eye on is the rear R/H side engine mount. Where it bolts to the block the bolts can come loose and one of them goes through into an oil gallery. When it comes out it dumps the engine oil. I remember blokes involved in a too and frow between Perkins and ASV with neither admitting responsibility over a stuffed engine.
PS. By R/H side I mean R/H side of the machine, rear is back of machine. Its close to the hiflow filter.
Amadeus3
Maine
Another dumb question but I can’t find it anywhere in my searching and it’s not in my manuals. Im probably missing it. What is the coolant spec for this machine? It’s got pink coolant in it now but I’d imagine there is a spec.
Tones
Ubique
That coolant would be Cat stuff and should be OK.
Amadeus3
Maine
Yeah it’s slightly low and I was going to add some more. Is pink coolant the same as any pink coolant? Or do I need to get more involved?
carlsnied
on topic, my pt50 2009 works great when cold, once warmed up stops drive power, unless revved flat out with foot throttle will not go forward or back. at idle control pressure is 390psi, the control pressure drops way low to zero upon drive stick roll on, when this happens. There is an adjustment point i have noticed below the hyd line that goes to the test point, that there is a lock nut is 11/16" and allen key adjustable thread, what to do?
Grass Valley CA
Sorry to bring this back from the dead....Did you ever figure out the laggy transition from forward to reverse? Also is it slow to come to a stop? I'm wondering if my cheap AW46 Hydraulic fluid is the problem....
