Tou
Hello all, I need help please. My quick attachment will not lock and unlock on my ASV RC100, it was fine before all sudden it quick working. I replace the solenoid and spool (view D, #4 ), check the wire (12 volts), the switch (12 volts), and the fuse. If the switch in unlock mode, the skid steer will not crank which is normal. The fuse for the quick attachment if you take it out it will still crank as long is on lock mode.
Is this normal ???. Can it be the switch???Is there a relay???
