topfli8979
I've got a weird issue here guys, just bought a 2008 Asv pt100 at auction.
The throttle lever on injection was tied with a spring to be advanced fully because the throttle cable is broke. I replaced throttle cable and removed spring to put pump lever back at idle... I can start machine it idles, moving the lever on top of injection pump does not adjust rpms much at all/very minimal. But of I shut engine off tie the throttle lever with spring like it was when I got it. Start engine it will run full bore rpm.. what the heck is going on?
Engine is a Perkins 1104-44t
