Anyone have one of these plasma cutters?
Jonas302
mn
I got a cheap one for for half that runs tig stick and plasma about 10 years ago and has worked amazing for occasional use
DIYDAVE
MD
I bought the hypertherm, sized to the 50 amp breaker that I have in the shop. Think it was about $2500, 5-10 years ago...;)
RZucker
Wherever I end up
Mechanic/welder
Availability of comsumables would be my biggest worry. I have two 375 Miller Extremes, and a Hypertherm 65. I hardly fire the torch anymore unless it's for heavy stuff. That 65 makes very clean cuts on 1/2" steel and does a good job gouging welds too.
petepilot
central shenandoah valley va,
I use a thermal dynamics pakmaster 75xl bought in 1998 still working strong . hooked to 200 amp service will clean cut 3/4 and sever 1in steel.
3/8 stainless is as heavy as i have used it on but i`m sure it would do same as mild steel. gouging gets to expensive consumables are pricey
RZucker
Wherever I end up
Mechanic/welder
I just use worn cutting tips to gouge most of the time. Gives them a second life and I have plenty.
Tones
Ubique
When you fellas are cutting steel with your plasma what gas do you use?
RobVG
Seattle WA
17 excavators and a stewpot of other stuff
Got one. Just opened it. First off the packaging is top-notch.
First impression- high quality
Hope to give it a try before the week is out. 30 day no questions asked return policy
Ebay
RobVG
Seattle WA
Wow. It works really well. Cut cleanly through 1/2 mild steel like butter. It worked as well as a $3000 unit I use. For the most part it looks like a quality unit except for the handle which is light plastic. The trigger guard is going to be the first thing to break.
muddog1975
knoxville tn
https://www.amazon.com/PRIMEWELD-No...rds=primeweld&qid=1551298455&s=gateway&sr=8-6
Link not working. "PrimeWeld Cut 60" Amazon.com
Looks like a heck of a deal for the budget minded. Maybe too good to be true...
We're not a production shop. It would see infrequent use.
Thoughts?
I bought on about a month ago. I have only used it a 6 times, but it has been great. Not a single problem. I run it at 30 amps, with 75 psi air flow. 3/8 cuts are effortless. I also use it to carve out some 1/2 thick material to allow a coupler pin to fit better. Like cutting through butter. The ground clamp is the only weak link I see. You sometimes have to move or resituate it. It is not heavy duty. I will be replacing it. But for 1/5 of the cost of others on the market. It works great for my needs using it 1 to 2 times a week.
