Ended up snagging the one we were looking at. Right or wrong decision, it is here. We were aware of some issues and made an offer accordingly. Of the issues, I will explain them below.
1. Hydraulics for implement functions are not smooth to start.. All 4 main functions seem to not have any fine motion at all. I observed the service page in the display for the joystick and shows that it goes to .3%, then jumps to .6% and bucket will move but abruptly start and will sort of jerk or stutter. Once you command enough motion, it is normal and smooth. This really feels and seems like an electric servo issue to me. Tuning or something. I did work through the display to select fine motion as it was set on course and it made absolutely no difference. The track system seems to act perfectly normal and smooth. Again all 4 main functions on right stick do the exact same thing.
2. Bucket/boom does not lift right and I am trying to understand what I am seeing. If bucket is on ground, when it starts to come up it is obvious that the left side comes up first and bucket is slightly angles. Not obvious, just subtle. When that happens the pivot arms in the back jump to one side as well. Nothing appears bent. I have no time in machine to figure out if there is a weak cylinder but with piston bypassing heat would certainly be a telltale. I just can't think of any other reason for what I am seeing. Are the cylinders not on the exact same circuit?
3. I thought there was one bad lower track roller, but there is more. I am looking for rollers if someone has any economical sources? trying not to put too much in this bird just yet until I can use it and see if we even like it.
