Any International gurus in the house?
hootsmcgoots
Chesapeake, VA
HE Parts, Service, & Sales
I got a new service truck about a month ago, 2012 International WorkStar (7400) w/ Maxxforce DT/ 6 speed.
Today on the way to a job with less than 1800 miles, the yellow warning light/warn engine shown on display started coming on, along w/ the engine fan and a significant loss of power:Banghead. The fan would only come on when the warning light was on and vice-versa. It was running at 185F so no reason for it to come on in the first place.
Truck seems to be running fine otherwise. The closest dealer is about an hour and a half away and things are way too busy for the bossman to let me take it there, even if it is warranty. Just want some insight on where to look, hopefully it's an easy fix. Thanks in advance.:usa:notworthy
Knoxville TN
Service Manager
Everything on that engine is controlled by sensors and the ECU. Although gauge may be saying 185F, are you certain that's what the engine temp is?
Being a 2012, and just 1,800 miles on it, I don't care how busy it is...it needs to go back to the dealer. If there is, in fact, something wrong and engine temp is up, it needs to be repaired without delay or you could kill your warranty.
bjs
gainsville / ga
lawn care speclist
hey ive got one for ya. ive got an 03 vt 365 4200. it was an old blue bell truck and now whoever had it before me put a dump bed on it 18ft. but anyway when i turn switch on and start the truck the check electrical system light comes on and the fuel light comes on and the fuel gauge needle goes all the way past full and goes straight down. will it be ok to drive or have someone come out to check it or can i take it to a shop. thanks for some advice.
Soodude
Sault Ste. Marie, MI
When that light comes on and it loses power that sounds like what a friend of mine's truck does.... Sounds like that exhaust flush or burn system is coming on... Not sure exactly what it is called I like the older trucks before all the emission standards started coming out.
hootsmcgoots
Chesapeake, VA
The temp is definately correct via IR gun.
I'm with you on taking it back to the dealer, but it's the company's truck. I'm just a pawn.:D
It's def not going into regen, some call it the afterburner. It's only come on twice since I've had it, both during periods of extended idling.
I accidentally figured out how to get the fault codes from the dash, I'll post em later
hootsmcgoots
Chesapeake, VA
Here are the fault codes. There are 5 stored, 0 active. The first becomes active when the warning light and fan come on.
SPN: 105 FMI: 4
OC: 0 SA: 0
Conn: -- PIN: N/A
SPN: 931 FMI: 11
OC: 0 SA: 0
Conn: - PIN: N/A
SPN: 639 FMI: 14
OC: 89 SA: 11
Conn: -- PIN: N/A
SPN: 1382 FMI:14
OC: 4 SA: 33
Conn: -- PIN:N/A
SPN: 2378 FMI: 6
OC: 3 SA: 33
Conn: 1604 PIN: G
hootsmcgoots
Chesapeake, VA
No, it isn't. There is a DPF light that comes on when it goes into regen. It has regen-ed before and this wasn't it.
DayContracting
Glen Allen Va
Delivery Driver(Rebar to jobsites)
I've heard nothing but bad new about the new workstars (navistar engines). I currently drive a 2006 Workstar 7600 with a cummins ISM engine and that truck runs like an OX!!! I've had it for 2 years and the only major problems i've experienced with it was a blown turbo. We lease all of our trucks and with that my workstar will be traded in within a month:Banghead. Im really not looking forward to the new workstar but I will take that over a p.o.s. durastar tandem.
Farmrod
Northwest arkansas
Does the truck sit and idle a lot? Does it ever get to open up and run? For the regen to work effectively the truck needs to run 45+ mph for at least 30 minutes.. Just because your regen light isnt coming on doesnt mean its not regening. Those codes you gave are generic codes if your engine light has come on there may be several codes you cant pull but the dealer can my recommendations would be get it to the shop asap sounds like a clogged dpf to me but thats just a guess hard to diagnose without having the truck hooked to the computer.
i would have to agree with farmrod. sounds like its not completeing regens and dpf getting plugged. most manufacturers have a point where you HAVE TO use the service software and force regen after its gone too long. thats IF you dont have to replace stuff.
Beto
México
warn engine
Puede ser que el sensor de presión de aceite esté fallando o tenga un falso contacto, te recomiendo revisarlo (quitarlo - limpiarlo y/o sustituirlo). Por otro lado, sería recomendable que al lavar el camión, no utilices agua en chorro directo sobre los instrumentos electrónicos, principalmente en los que están muy cerca del piso, a un lado de los pedales de clutch y acelerador, ya que con poquita agua que les entre, causa una variedad de problemas, entre ellos el que tu tienes, por tanto revísalos también.
Saludos y espero te sirvan los comentarios.
95zIV
Cincinnati, OH
RR Contractor Super.
Beto,
On here the rule is to use english because that's what the majority of us speak/read.
I have run your post through a translator and will repost for you.
warn engine
Maybe the oil pressure sensor is faulty or has a bad contact, I recommend you check it (remove - clean and / or replace). On the other hand, it would be advisable to wash the truck, do not use direct water jet on electronic instruments, mainly those close to the floor, next to the clutch and accelerator pedals, because with a little water to among them, cause a variety of problems, including the one you have, so check them out too.
Greetings and I hope you serve the comments.
On another note, the new Internationals do have a recall on them because of the regen systems. Take them in and get them checked! Our newest truck 2011 tried to burn itself down last week because of the faulty systems.
Deereman
Georgia
I know this is way old but sounds like you have a bad ground or a short.
