I am struggling with hydraulic/electrical issues on a Hitachi 120 which seems be fairly common based on my reading here. Problems started out with the operator complaining that occasionally the machine would "stop" mid swing, said it would just slam to a stop while rotating but was never able to see it happen myself as it was an intermittent problem but it did seem to increase in frequency as the machine & weather warmed up. The next issue was that it would only track at a very slow speed, i unplugged the pump control coil and machine was able to track at full speed to allow it to be moved to shop. Seems something is not telling control valve to increase pump stroke, and i am not sure where to start? Angle indicator, pressure sensor, ??. Also curious if the swing issue could be caused by a pump going to minimum stroke and the pressure dropping so quick it is setting swing brake. Located in a pretty remote area and getting any outside help means boat and or plane rides so we would really like to get this problem resolved ourselves if possible. Thanks for any information or tips you may be able to provide.
