Junk runner
Im going to put Allison’s in a couple of my dump trucks That have standard transmissions at the moment. I posted on here earlier about a stand alone harness but believe I have that taken care of now. The next issue is getting the right flex plate and ring gear with adapter. I have been looking for used ones with zero luck so I may have to get new ones or at least if I had the numbers of whit I needed it might be easier to come up with used ones. If anyone could help me with the correct numbers that would be very helpful. I need the transmission adaption kit number and the engine adaption kit number and would like a break down of the parts included with numbers if at all Possible. I have called Allison and they are less than helpful unless you are a distributor. They just give you the number of your closest distributor who really doesn’t have the time or desire understandably so to help. I’m wanting to put a rds4500 behind a 2000 cat c15 in a kenworth the second is an Rds4500 behind a 1999 Cummins n14. Any help at all would be appreciated. Also I’m going gen 4 electrical pre prognostic which is 2006 to sometime in 2009 i believe. I could use a shifter keypad number that works with the gen 4 Pre prognostic.
