Alcohol Injector on Trojan 1900 Loader
Jackf
HENRIETTA
I goofed today !!, I put DOT brake fluid in the alcohol injector reservoir. I ran the loader for a few hours before I realized.
I emptied it out but Did I do any harm to the air brake system ?
Thanks for any info
kshansen
Central New York, USA
Thanks for any info
First off DOT brake fluid should not harm any of the rubber seals and parts in the brake system. Second due to the higher viscosity or the brake fluid I have my doubts that much was even pulled into the air system. I would just drain the air tanks when done for the day each night to see if any thing comes out. Actually that is something I would be suggesting as a standard method of operation!
Jackf
HENRIETTA
Thank you very much kshansen, you put my mind at ease ! I also noticed the selector dial was set to "0" which is the closed "summer" setting so I don't think any brake fluid found it's way into the system !!
