SeaMac
What would be the smallest gas powered compressor you could get away with to fill a wheel loaders tire with air? Here are the particulars, we have a Volvo L70E Loader with a minor air leak in the front right tire. Yes, we can road it to a gas station and sometimes we do but they charge for air. We found a gas powered compressor that obviously fell off a truck, it's a Coleman Powermate other than some road rash on the reservoirs it works great but it won't put more the 30psi in the L70E's tires.
Compressor specs:
Tank
•Size: 4 Gallons
•Style: Pontoon
Compressor Pump
•Style: Oil-Free Direct Drive
CFM
•6.9 CFM's @ 40 PSI
•5 CFM's @ 90 PSI
Pressure
•Operating Pressure: 155 PSI
•Maximum Pressure: 155 PSI
Power
•Source: Gasoline
•Horsepower: 5
Shouldn't this compressor do the trick? We generally run 50psi in the tires and I would have thought this compressor would be able to get the job done. Or, could something be wrong with the compressor, it did fall out of someone's truck?
If this compressor is too small could someone please advise as to what size would do the job? It has to be small, it goes in an 8' pickup bed along with a plate compactor and various and sundry "other" items so space is limited. Thanks...
Compressor specs:
Tank
•Size: 4 Gallons
•Style: Pontoon
Compressor Pump
CFM
•6.9 CFM's @ 40 PSI
•5 CFM's @ 90 PSI
Pressure
Power
•Source: Gasoline
•Horsepower: 5
