doublewide
..... check valve should be present that prevents primary or secondary air from leaking to another tank.
Check valve bad from wet tank to the next tank?
Check valve. That was my guess. If the check valve at the secondary tank is malfunctioning, air can leak back to the wet tank and then out through the leak at the rear axle primary tank.
