oifla
Hello all,
I'm sorting through some issues with my International 8100. When I first got the truck, it would take forever to build air pressure (like 20+ minutes). I located a faulty gasket/seal atop of the air compressor. I replaced that, build pressure normally now.
Now that the compressor isn't leaking, it builds too much pressure. Goes way past 150 psi, so much so that it blew a line on one of the tanks yesterday after a drive.
The setup on this truck is not one I'm familiar with. It doesn't have an air dryer and I'm not sure how it is all supposed to work but I'm guessing something is wrong (high PSI readings and the blown line, etc.).
It does have a bottle with an anti-freeze solution in front of the compressor: https://photos.app.goo.gl/o7SwXRPuLtPxsyDQA
I'm not sure what else is on the compressor itself but here's another pic of the back of the unit: https://photos.app.goo.gl/ZeAX51pdkrurFx1LA
The tank setup is a little confusing to me. There are two tanks and they don't seem to be connected (they can be emptied individually via manual valves on the sides). Only one tank seems to have a pressure relief valve (labeled B in this pic) and it also has a manual drain that seems to collect a ton of wet gunk (labeled A in the pic): https://photos.app.goo.gl/qAYnHvrsirdaLtg5A
Both A and B can be better seen here: https://photos.app.goo.gl/L3BFAxDQ5dYFdgHA8
The pressure relief valve seems to not be working correctly so I'm getting a new one.
The back tank doesn't have any pressure relief as far as I can tell (hence the blown air line). There is a quick connect for an air hose (labeled C on the following pic: https://photos.app.goo.gl/Fp2LeZTBEJM5jE2eA). I'm not sure if that's where the pressure relief valve goes on that tank and someone thought it would be handy to have a quick connect or what is going on with this.
What I labeled as D is another mystery item. It it attached to the first tank and looks like some sort of pressure relief but it is covered with a rubber cap. I'll get a pic of the 'valve' next time. No clue what its for.
Anyhow, that's a lot of info (sorry!). Advice from anyone who knows how these systems are supposed to work would be greatly appreciated as I am at a loss right now. I can take more pics if it helps, let me know what you'd like to see if I missed anything. Any help would be super appreciated. Thanks!
A.
A.
