HighFly27
- Joined
- Feb 15, 2014
- Messages
- 28
- Location
- Bonifay, FL 32425
- Occupation
- Retired ~ Currently Buying Hvy. Equip. for Big Pon
I'm Looking at a -- 1999 Samsung ES 280 LC with 39XX hours. The 280 is really nice looking and shows low hours as well.
I found a -- Control Valve for the ES 280 today, it was used (from a 1400 hr.'s. mach.), the price is $ 7,000.00 dollars. I called Volvo and they will get back to me, it will be special order... estimated new at $ 14 K.
The guy that had the dismantled SE 280 (was a roll over) said that he'd steer away from the 1999 SE 280. It's quite possible that the Hyd. System is Loaded Up with Metal. I'd be in big ($$$) trouble with pumps, everything is subject to being crippled by a Hyd. System with lot's of metal going thru it.
I'm a retired hvy. mechanic and did mostly engine work and know all about gutting out a engine with metal.
So, My Question... is this SE 280 a machine that You'd Run from !?! My bid is $ 15 K for the ES 280. I see the Samsung SE 280's selling for a average price of -- $24 to $ 34 K.
Earlier, I figured about $ 5 K for the Control Valve, now it's $ 7 K, and used & as is. If I got into the Hyd. Pumps, then another $ 10 to 12 K and parts only. So, the add up math is -- $ 15 {hoe)+ $ 7 {valve) + $ 12 K {pumps) = $ 34 K and No Labor.
I'd like to hear from the folks that have been down this road before {Failed Control Valve) ! What did You Do to return your machine back to service ? Did you replace all the Major Hyd. components or Not; .... or did your Hyd. Components Fail a Short Time Later because of Metal in Hyd. System ?!?
I heard this SE 280 Control Valve is made by Toshiba. It's a Twin Module Design, the halves are piggy backed to each other.
Thanks'
Avery
Thanks'
Avery
