Queenslander
Just not sure what flow ours is producing but they work fine through 1/2 inch hose into twin cylinders.
That’s a fair point about the twin cylinders. It might be a bit small?
I think they were 1/2” I was going to go back later with a ORF fitting from cat that is the same as on the tilt cylinder hoses, so that we can try and work out what fittings and hoses I need. I want to try and set it up so that the tilt hoses stay as is and go to the new valve, then the new aftermarket add on hoses can sort out the in between. So what is standard stays standard for easy hose ordering and replacement.
Ah Queenslander said his has 1/2” hoses so might be ok.
I hadn’t thought about extra remotes. I don’t have a use for them right now but there is a few things I wouldn’t mind trying in the future that they would be handy for. I had already got all the bits when I saw this so I will just go with what I have for now. I don’t think it would be too hard to add extra later.A bit of an afterthought. Have you considered adding a set of rear remotes while you are at it in case you pull some implement down the track? Nor knowing what your application is going to be, but if agricultural, you can do some different stuff.
