A40D
Discussion in 'Other Earthmoving Equipment' started by Dave Neubert, Dec 1, 2018.
  1. Dave Neubert
    Dave Neubert Senior Member
    Jul 19, 2018
    323
    Monroe NC
    the transmission is acting like when you go from 1st to 2nd with it in the drive mode that it goes into 2 gears for a moment it will make a loud clunk and jerk. but if you shift manually it don't do it. does this machine have codes that will show I have someone that can plug into it but don't know how much it will show. The Volvo dealer here wont even give a idea when they can come out to scan it
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,563
    Mechanic
    Will county Illinois
    Check the oil in your dropbox. ? Aside from that, on your keypad hit the trans icon, scroll down, if there is an active it will be at the bottom of the list.
  3. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    I will look I don't see a key pad though
  4. funwithfuel
    Mar 7, 2017
    1,563
    Mechanic
    Bottom left of dash, 12 buttons or so. Pic of eng gears, axles etc
  5. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    Ok thanks I know nothing about Volvos
  6. walkerv
    walkerv Senior Member
    Jan 22, 2016
    645
    wingate nc
    If you set asc up to come out when all there techs are swamped you will literally have to call them everyother day to keep getting updates of when they will make it out . I have been there woth them its bad sometimes, try your best to get them to nail down a date
  7. walkerv
    Jan 22, 2016
    645
    wingate nc
    What range is the drop box in. It sounds like it is in high range . When in high it takes off in 2nd low then immediately goes to high of i remember correctly. We ran ours always in low range where my guys hualed they had no need for highrange
  8. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    I will look is there a high low switch to switch drop box. Machine belongs to a customer they have been trying for 3 weeks to get them out they will not even give them a date
  9. funwithfuel
    Mar 7, 2017
    1,563
    Mechanic
    Just to the left of the gear selector should be a rocker switch with an L and H on it
  10. funwithfuel
    Mar 7, 2017
    1,563
    Mechanic
    On your instrument panel below the gear selected a small L or H will be surrounded by a Box dependent on which way you have the rocker flipped
  11. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    Thanks I found it it seems worse when in low range if something is wrong will the screen give you a code because nothing came up that I could see but the alert and stop light is flashing
  12. funwithfuel
    Mar 7, 2017
    1,563
    Mechanic
    That would be the central warning. You've probably got a hurt clutch. I guess you're gonna have to rely on the dealer.
  13. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    Thanks been trying for 3 weeks to get a dealer out to look at it
  14. sfrs4
    sfrs4 Well-Known Member
    Jul 22, 2013
    94
    parts admin
    Great Britian
    drop a bit of oil from the trans and check it for debris, or if it's burnt, either is a good sign of a failing clutch pack
  15. walkerv
    Jan 22, 2016
    645
    wingate nc
    Is the customer in polkton? If it is i know the machine and can give you some history
  16. funwithfuel
    Mar 7, 2017
    1,563
    Mechanic
    I believe it was K2 in the early transmission was identified as a weak link. It's in the extreme rear of the trans. If shrapnel hasn't traveled throughout, it may be salvageable in chassis. Not to give false hope, just a possibility.
    Good luck
  17. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    No its in Monroe Center Line Who are you with I should know you
  18. walkerv
    Jan 22, 2016
    645
    wingate nc
    I was with waste connections for the last 8 years , this spring i went to j.o. flowe in midland
    Dave Neubert likes this.
  19. walkerv
    Jan 22, 2016
    645
    wingate nc
    2nd is what went out in the one i took care also , not a fun tranny to change, dont think its a weak link persay as it always takes off in 2nd gear especially if drop box is in low
  20. Dave Neubert
    Jul 19, 2018
    323
    Monroe NC
    Is there a dip stick on the drop box
