gladiatore
Thanks a lot guys I changed accumulator and the hose that goes to the double pump, give service to pilot system and change base from valves from controls because was broke, really thank you with all my heart
There is a strap preventing two bolts from coming out until it's removed, it covers a hole that will let out any nitrogen if not drained.
Later Bob
In that case my suspicion would be on the pump not destroking in response to the accumulator charge valve signal.
I already changed
3 acumulators
Sorry, didn't check. I thought it was a variable displacement pump.
Oil isn't going to the cooler for some reason .......... your challenge is to find out why. Maybe you have a blocked hose somewhere.Cooler hoses are cold hyd hot like crazy
