JakeHarrington
Hey guys Im having some trouble with machine overheating. The hydraulic fan doesnt turn somedays. Today is the 4th or 5th time i have had this happening. The machine will run fine for like 2-3 hours and then ill notice the engine temp gauge start to creep up. So i get out of the machine and see that the fan has stopped spinning
The serial number on the machine is JMS03132
So far i have tried cracking a few lines to see if its air bound. That doesnt seem to make a difference at all.
i tried unplugging two solenoids also. One that goes to a little aluminum block with three lines goin to it. I believe that controls the control oil to the piston pump. Unplugging also does nothing.
I also unplug the solenoid back by the big aluminum block by the radiator and battery shut off. That also makes no difference.
thankfully i have a spare smaller machine on site now. But i have to get this thing running consistently. Chances are after a night of sitting when i start it up tomorrow all will be well.
Any help is greatly appreciated
Thank you in advance
Jake Harrrington
Jake Harrrington
