79Miner
I was working with the 980B and the engine started to miss and have lower power at full throttle. I noticed the fuel pressure had dropped when at full throttle however at low idle the gauge shows good pressure although its on the low end of the green. It didn't do this when I first moved it to the shop and showed excellent pressure on the gauge. First thing i wanted to do is get a new fuel filter. Currently it has a Baldwin BF7633 and I'm wanting to find out the correct number for a Cat filter replacement. The loader is serial number 89P2853 and the engine is a 3306 with serial 3N10981 arrangement number 2P6812. The machine had the fluids and filters changed not that many hours ago but its was 13 years ago. The oil filter on the engine is 1R-0739 and mention in case that's not the correct one.
Aside from fuel filter if you have any ideas on troubleshooting the low fuel pressure feel free to pass them along. Thanks!
