want 2 get high
Hi all, having another issue with the lift. Here lately the throttle control module is acting up. While in the basket if you do not use the controls with in a short amount of time the control module goes to a red light. If you push the control button to off and then pull it back out you can then hit the foot peddle and it will work again until you stop using the controls for a short amount of time at which point it will go back to a red light. As if it is timing out. What would be the cause for something like this? The controller is not that old with very little time on it.
Thanks
Dave
Thanks
Dave
