Bullseye Beaver F.
Need tips on how to remove primary chain sprocket on a 960 mustang skid steer. Just acquired the machine and the manual is vague on the procedure.
The shaft in the diagram three different styles of shaft retainers, the one at bottom of the page is the upgrade replacement, all others obsolete, figuring out which shaft is the fun partBig one. The cluster sprocket. Down to getting shaft that goes thru sprockets out.The bearings are gone on it.
This looks like a fairly recent thread.
Do either of you guys have a bead on a new 80HK chain, the big one between the axles? I had a cluster sprocket bearing failure and it took out my chain as well. I was able to find websites with all other pieces that I need, but unable to find anything for the chain. Thanks ahead for any input!
Try ATS Clayton, Inc. PhoneThis looks like a fairly recent thread.
