Bryant_955L
I was looking at my motor manual, and I noticed that it shows a set of sleeves on the crankshaft. (Under the crank shaft seals and they are called wear sleeves) I am confused because the motor I pulled out did not have any of these sleeves. I am replacing my motor with a different motor (long block). My question is when do you need sleeves and should I install them on this new Long Block motor? I think if I don't install them my new motor will leak. Need help or suggestions on how to install them as well?
