953c transmission getting hot
Andrew01
North Carolina
Im new here and trying to learn this website so i need help i got a 2000 953c sn# 2ZN03520 little over 10000 hours loader runs good and has good power about 3 hours in moving dirt the transmission/drive train Gage gets hot and the light starts blinking it does not go into limp mode I pressure washed the radiator checked all fluids
Andrew01
North Carolina
Not sure on oil in transmission planning on changing it and all the filters
Far as coolant water and regular antifreeze and no it doesn't heat
Not show all the components replacement just bought it 3 weeks ago
10W Hydraulic is the recommended oil, so you're not far off there.
If it has green "old style" anti-freeze in it a switch to a red ELC coolant might be worthwhile.
Next step would be to change transmission oil and filters, cut old filters and look for particles in the bottom of the pleats. Personally I'd go for OEM filters and a good brand (Shell, Mobil, etc.) 10W oil.
Do you have an Operation & Maintenance Manual for it..? Best $50 you'll ever spend.
Andrew01
North Carolina
Ok will do on the red anti-freeze
And i got all cat fiters for it now because the filters that are on it now are car quest brand
And no i dont have the operation and maintenance manual
For a manual, go to https://catpublications.com/
On the popup click, "Continue as Guest"
Type SEBU7115-06 in the box and hit Search. That is good for all 2ZN-prefix machines above 1750, yours is 3520
The illustration below should be at the top of the list that pops up. $46 for an immediate pdf download, $55 (plus S&H) for a paper version.
Cmark
Definitely transmission temp and not hydraulic temp you're looking at?
If so then it's the splitter box that's getting hot. Check its oil level. It only holds a couple of gallons and if it's overfull it will overheat.
Cmark
Believe it brother.
Let me tell you about a main marine C32 suffering from chronic overheating. After several expensive weeks of troubleshooting, it was discovered that someone had swapped the dipstick with one from one of the gensets, resulting too much oil in the sump.
Oh, and the genset was underfull, but no damage luckily.
The reason it was found is that someone *raises hand* compared the dipsticks from the port and starboard engines.
Lol lets hope im puting new oil and filters on tomorrow night so we shell see
Well if you are doing the full service I hope you took the advice of Nige and downloaded the manual so as to not miss something or get levels worng by checking them in the wrong way or miss a washout filter that may not be obvious.
Oh and don't forget to drain water and crap out of the fuel tank, one of the most important steps that gets forgotten!
