Yes, make the adjustments with the cover off. If it flings too much oil about you may need to drop the level a bit or place some rags over the top.
Yes, the broken part(s) are for setting the pump neutral. The other two are for making the steering equal on both sides. Don't worry about those.
I hope you haven't bent the spool valve. You could also have damage to the cardan joint which you can just see down the bottom of the bore in the valve housing in this pic from my transmission overhaul thread.
