melben
- Joined
- Jan 14, 2008
- Messages
- 1,029
- Location
- Williamsport, Pa
- Occupation
- Retired 50 Yrs with Case dealership
What kind of abuse do you think that machine should stand?????? I have seen external abuse cause broken chassis in the axle housing areas, I have seen bent cylinder rods, belt loader frames, just about any damage that abuse can cause. Let's see what actually caused your problem and then assess the situation, could be something entirely unrelated to dirt that coincidentally happened. Hydrostatic systems are some of the toughest drives on the planet and are being used in very large crawlers of very high horsepower. Most brands of equipment use systems built by one or two major manufacturers and their designs are so similar as to be indestinguishable. Your machine ran years till the hose failure. What you are looking at as a toothpick is a really well designed and implemented technology that has proven itself in millions of units with systems just like yours. I am not going to pass judgment till we find out if abrasives actually destroyed your pump, but if so that would be akin to dumping sand into a transmission or into an engine that did not have a filter and complaining about the poor design when certain failure occoured. The system is fine as designed and adding filters would be fruitless, as I previously stated if that abrasive material moves through those finely machined precision areas one time, the damage is done instantaneously.
