heymccall
6500hr 930K, RHN prefix, engine derates about every 10 hours or so.
E396-2 "Fuel Rail Pressure High "
No other codes present.
I changed rail pressure relief valve, no change, but, event was active the moment machine was started (even though rail was drained to change valve).
Dealer put fuel pressure regulator in, as a guess.
Rail pressure sensor calibrate on ET went thru normal.
But, machine still aborts the following:
Relief valve pressure test
Rail pressure test
Both tests abort with either "rpm too high" or "rpm too low" right around 1530rpm in each test.
Screen shows this...
Rail pressure test
