aubuchon72786
Tank was in the 160s when hot
Where exactly are you reading that.?My signal wire leaving altinator is putting out 14.2_14.7 the book says it should not be over 14
2 questions this morning, a neutral safety wire on my foot pedals about the time this started could that throw wrong signals? Question 2 the pilot hose r4 leaving pilot bank and going to valve bank is pulsating bad, what does r4 controlI was the one who was barking up the electrical tree, at the time there was a lot going on with the alternator, batteries dying, rewiring, etc. I may have been confusing this thread with another thread with electrical codes or warnings. 14.2 IS about 14V, even 14.5, 14.7 maybe questionable, but I'd have a hard time replacing a computer just for that.
I still think from what you've described of the electrical history, that this is worth looking further into, but I can't guess where to look, other than follow the diagnostics through without skipping any steps. After you've verified the computer is getting all the correct voltages and grounds, then I'd think about a new computer if that's what the diagnostics tells you.
15V or 30V isn't a problem by itself, it's not hurting anything, it's more a question of what it's supposed to be and why is it that way? it might be hinting at the problem in a round about way.
Can you repost thejust to double check the engine bogs down from the go or just after the oil warms up? if you want you can give me a call, pm me and I can share my number
So If you scroll up in the conversation there is links u can click on to access the manual, to calibrate it you need to hook hydraulic gauges up and than the rest is done from the monitor step by stepCan you post the procedure you used to check/adjust the PRV? What is the pressure when cold after you made the adjustments? I have a similar problem on a 311B that I am starting to troubleshoot (I’ll start a new thread so as not to hijack yours).
